First Off, Outstanding Forum!! My first place to go and is a fantastic source.
Have an Advance with ESP Black wires) about 20 yrs old. Has been unbelievably reliable.
My setup is I run the stove with Auto/Man in Manual, Wall Tstat in series with temp sensor.
Honeywell setup as described here and at Harman. Temp set at 75 all day/night.
Completely cleaned Jan 25.
Issue: The stove has kept the room temp at 75 +- 1 degree for years. Last week the room temp has climbed to 83, pellet feed seems to be a consistent amount keeping the pot pretty full and flame higher with the 4 LED Flash requesting "Keep Alive Idle" . The stove body temp is actually keeping the room hot without the distribution fan running. So with the LED flashing 4 times indicating Tstat circuit is "Open" the stove still runs as if the circuit was needing heat but the distribution fan does not run.
Moving the Auto/Man switch to Auto and the Tstat at temp, 4 LED flash, the stove pellet feed stops and shuts down as it should, then refilling and igniting when the 4 LED flash goes solid.
I'm wondering if the ESP is become inaccurate. I cant find any other reason.
A bit more visual, while in 4 LED Idle, the pellet feed does 3-5 feeds in about a minute ramping the flame up to typical catch up but with no dist fan run then stops till the pellets burn down into the burn pot bottom then starts a repeated pellet feed of 3-4 again. The "Feed Adjust" set between 1 and 4 doesnt appear to change feed rate. Has very good flame shape and draft. I ran the stove in Auto last night and room temp was 75 this morning.
Any thoughts please,
Thanks Jack
Thanks Jack
