Harman Advance2 burn pot gasket needed.
flashbang
135
NY
Anyone know of a good online place to get this gasket. Found one but it's $10.00 for a kit that includes a tail pipe gasket that I do not need. Or maybe make a abestos gasket?
TIA
Contact Eric at Kinsman Stoves. He is a forum member and a Harman Stove dealer & Certified tech. He is a great guy, and will do you right on parts....if you mention you're a Hearth forum member, he will give you a discount.
Tell him iMacman says Hi!
330-448-0300
(broken link removed to http://www.kinsmanstoves.com)
330-448-0300
Sent email, Thanks
Yes they are a Lytherm Gasket. Harman only has them available as a set with the tailpipe gasket. A couple of years ago the burn pot gaskets were available seperately and I am not sure why they changed. You can make your own fairly easily with gasket material from elsewhere. Just a time vs cost question really.
yea, some dealers split them from the tailpipe gasket......individually, they will cost around $4.09 each, but shipping, tax, etc will likely eat up any savings. Local is best, if you can find them.
Hello
I can see from the link they are Lytherm gaskets.
(broken link removed to http://www.stove-parts-unlimited.com/Harman_Burn_Pot_Tailpipe_Gasket_Set_p/1-00-07381.htm)
You can do alot better if you make your own!
Here is how I made one with pics and link of where to buy the material cheap!
https://www.hearth.com/talk/threads...lytherm-gasket-from-sheet.86680/#post-1119377
You should not make the birn pot gasket out of lytherm. It will squeeze into the primary air holes for the burn pot. The gasket needs to rigid.
I grabbed one of the burnpot gaskets we have here and compared it to some samples we have of various flat gasket sheets, and doing a direct comparison I am going to change my statement from to Manniglass for what it is made of. That's what I get for answering from home without checked first.
Eric, at Kinsman Stoves took good care of me. Thanks to all!
