harman circuit board for p61
kelly
67
rockwood
just looking to get a spare board for the old stove and can I use the Harman 1-00-05886 board with the black esp and change the dip switch setting - am I correct - or do I need a different board all together thanks
You can use the new board with the black or red ESP. Just change the dip switches. Now an older board likes to have the black ESP.
(broken link removed to http://www.hechlers.com/store/index.php?main_page=index&cPath=13) Best prices and service for Harman parts I have found.
Thanks for the reply - so I have read and understand the only difference is the 05886 can be used with the manual start stove p61 and just change the dip for the esp probe thanks
How old is your P61? Have you had any issues with it yet or needed to fix / replace anything? Thanks
Understand that I bought used but believe these stoves are the best available - I got under warranty a new auger body and burn pot - they tend to burn through right at the auger tip/ burn pot , Harman forwarded the parts - I had to install . and I have replaced the esp - you cant go wrong with them other than a gas stove if gas is available . or you can burn wood .
I did forget to mention that I don't have a problem with the board nor have I heard of problems with the boards - the spare board is only when or if I did have a power surge that got past my recommended surge protector I would have it covered and continue heating comfortably . I do not wish to suggest that the boards are known for , what is known is that when power outages occur the brown power while bringing back power can deliver spikes that can blow out small resistors in the board - get a surge protector and blow the fuse on that instead - hope this helps
Newegg had a great buy on a 1500 Cyberpower UPS($100) that would be a better option than a purchase of another CB and #!** surge strip
