Hi all! So a recent thread about "cold weather pellets" got me thinking...
Harman stove heat output is governed by a user set temp(be that a degree temp on room temp, or a esp temp corisponding to anumber(1-7) on the dial when in room temp mode) , not by a user set feed rate. That allows the stove to automatically adjust the feed up or down as necessary to keep the set temp. All of this is explained on the Harman sticky and it means that if using low grade, low btu pellets, the user need not be concerned about adjusting set temps in order to compensate as the stove will do it for you.
My question :
Can you reach max btu rating (43k in my case) with a quality pellet? Will the stove ramp up feed rate to reach that output, or will the stove eventually hot a point where you may need higher quality pellets to reach 43k?
And related, is the stove maxed out by feed rate, or esp temp? Ie will 9500 btu DF pellets, if turned up to 7 on stove temp, produce 43k btu because the stove will limit total output (due to esp hitting whatever temp harman set for feed rate 7? Or can it go above 43k if your pellets have the high btus?
This is mostly my curiosity asking. I do have a stove that is running at about 75% right now, (0 to-10) and we have a LOT colder to go still, so this may become a practical exercise for me as well as an academic one.
Thanks for your input!
My question :
