Hello,
I am new to register, but have been using this wonderful site to aid my wife and I in making a new pellet insert purchase. We have just purchased a new Harman P52i. It is quite a bit more stove than our 12 year old P23i Breckwell. We were having to run the breckwell at mid to upper settings to achieve the heat output we were looking for, but this created unwanted loud fan noise. Judging by the heating range of the P52i of 900-2600 sqft, and the innovation of the more automatic room temp mode we felt this was a good option. We have a smaller home, around 1200 sqft, and the stove is located in our living room, which is open to the dinner room and fairly open all the way into the kitchen. I've read about as many threads as i've been able to find, the latest being by
lbcynya titled "How your Haman works, what the manual doesn't tell you. My question is based on the auto room temp mode, and the shut down start up sequence. Here's what i've got going on. I have my stove set to auto ignite with the feed adjuster set to the recommended setting of 4. My temp dial is set to 70° and I turn the Blower/Mode selector from the off position to the room temp L position. The start up sequence works flawlessly as it cranks out a large flamed fire until the distribution blower kicks on. After initial start up the stove ran for about an hour of so before it sensed that it had reached the desired temp and started into shut down mode. The flame burned out completely and after about 30-45 minutes I noticed the room temperature getting pretty cool. Not being the patient type I decided to turn the temp selector up to restart the fire. What I noticed was that I had to turn the temp selector up to almost 80° before the light came on and initiated start up. I was under the impression that to start the stove on room temp mode your dial has to be set higher than the actual temp that the sensing probe is reading. It was certainly not 80° in the room, so i'm beginning to have some doubt on the operation of the stove while in this mode. My temp probe is set about as far away from the stove as I could get given the length of the probe wire extension. I'm guessing here, but probably around 10'. I have it stuck behind the couch with the tip of the probe sticking about the top at probably around 3' above the floor.
Last night was our third night running the stove. The first was a similar experience. We set it to 72° turned it on, and we couldn't figure out how to get it to run cool enough. Finally after reaching a roasting 78° we tried turning down the feed speed, then just turned it off. Tuesday night I just said the heck with auto mode and and started it up in stove temp mode then turned the feed speed and temp dial all the way down. This seemed to give us a liveable temp in the house but left me with a feeling of why did we pay this much money for a new stove if we can't get it to run without messing with the settings. I realize that these issues are probably based on my lack of knowledge in the operating procedure, i'm just kind of hoping someone can straighten me out. I was under the impression that this stove was kind of a set it and forget it operation. I like the idea of the stove ramping down after it's met its desired temp, i'm not sure i like the idea of the igniter probe having to keep working to restart the stove, if in fact the stove ever restarts. Sorry about being long winded here. That's kind of my M.O. Thanks in advance for any advice. Jim
