Harman P61A Power Issue
Pell
4
New Hampshire
The fed motor is not working on this stove, checked if it power, it did so I assumed it was no good. Replaced it still not working. Rechecked voltage and found the neutral wire is reading 96 volts. Finally found a wiring diagram and assuming it is a problem with the igniter. Has anyone had this issue? Thanks
Did you mean to say feed motor (aka augur )? If you put it in test does the augur turn?
sam
