Harman p68
Dmusser37
2
Pa
I have had a harman p68 for 3 years now. I have messed around with differnet pellets and settings on the stove. Im burning 5 ton a year in a 2200 sqft ranch. Keeping the house around 70 degrees and eating 2 plus bags a day. I have been complaining about the eating thru pellets since day one. I have had it set on thermostat and room temp. Laat night was the first night i turned my stove on had the blower turned just under half way stove temp at 1 and feeder set at 1 and it thru a bag of pellets in 12 hours. Is this normal. The place where i got the stove from said that everything is normal. It was 30 degrees lastnight and i qas using my heat pump as well
Sounds pretty normal to me. It would be really great if your house was poorly insulated.
Sounds like you need to work on more insulation and seal up some drafts. I'm burning a little less than a bag a day in a 2200 sq ft ranch. Family room where the stove is at is 70 on room temp auto and the other half of the house is 65. Until this last couple a days no propane used. Now propane furnace runs about 4 or 5 times a day for about 10 minutes each time. Last year I burned 3 tons of pellets and 500 gallons of propane for the whole year. That does the house heat and water heat plus my workshop heat when I use it. House is super insulated and I heated my workshop to 65 about 20 - 6 hour days last year.
Ron
I have a poorly insulated house..1928..lot's of windows...thermal glass but still more glass than walls.
on very cold days i go thru a bag in 11-12 rs.. running a P61A..
Bigger burnpot holds more burning pellets...less burn time.
I have a P68 in my basement for the house. I run it on stove temp (2 1/2) and feeder rate around 4. I am using 2.5 bags a day, ish. I am new to the game.....like Nov 1st install new. I thought that was a lot also until I asked my retail guy. He said that is pretty normal.
