Hello,
have been searching through the forums looking to see if anyone else is having similar problems as I am, but figured I would post and see if anyone can lend a hand.
I’m up in Alaska so when I say we run the stove a good bit, it is not an understatement. The house also has a pellet boiler as our primary heat source with an attached 4 ton hopper for our pellet supply. We have had this particular stove and have had zero issues over the last two winters.
About 3 weeks ago, I started noticing the stove would not run overnight. The inside of the stove was also covered in black soot. After reading the manuals and other forums, the stove got a very in depth cleaning to include the removal of the rear panels and the plate for the feeder fines. The exhaust probe was also cleaned and the flue was removed and cleaned as well. After cleaning, the stove would run through it’s ignition and once the flame was visible, the blower would pulse 6-8 times until the flame was self sufficient. Roughly ten minutes later the flame would start to resemble a lazy campfire and eventually go out within an hour. Sometimes I would get 6 blinking dots, sometimes I wouldn’t.
At that point I choose to order a new combustion motor and fan blade and with the help of some parts from the lower 48, see if that was the problem. Install went just fine, gave it one more once over with the shop vac and reinstalled. Fired it up, normal start sequence with one 5 second blast of air to get the flame going and everything looked normal. Threw a five gallon bucket of pellets in and set to having a few beers thinking I had figured it out.
Next morning the stove was running wonderfully, had been for the last 16 hours, and then it went out and back was the black soot everywhere, most noticeably the glass.
So just finished cleaning it again and writing this post to see what you fellow pellet burners have for me.
Thanks
Thanks
