If you energize the stove, the combustion blower red light comes on for a couple of seconds, you can hear the motor turning, then the status light flashes a half a second and then a solid red power light. Normally if there's a fault, it would blink 1, 3, 4, 5, or 6 times. I guess someone else took the control cover off and found a short in the wire box where a wire nut burned through and was touching the metal. Problem is where I live, no one wants to work so it's near impossible to get a qualified tech out. On my regular furnace I had to replace the exhaust blower motor, upper limit switch, rewire and replace the damper motor. Not like I do not know how to use a meter... I've looked at the wiring diagram. there really isn't much explanation of the control board except the sensors and low voltage wiring. The average price of the control board is about $260. I'd hate to replace it under the assumption the wire shorted out to ground, but all indications point to that with it not firing up or flashing an error code.
