I bought a used, 2006 Harman XXV last year. I heated my house the whole winter without problems in room temp mode (manual). This year, it started for the first week just fine, then we had two days of 70+ deg days so I turned off the stove for those days. The temp sensor is set up behind the stove ~5' off the ground. During the week room temp worked, the room temp was exactly what the dial said it should be. Now it will not feed pellets in room temp mode.
I start my stove on stove temp/manual, then after it is going well (15-30 min) switch to room temp. Even if I set room temp to 90 deg, the feed motor does not come on, no pellets are fed, and the fire burns out. There are no problems in stove temp mode -- pellets are fed, blowers work, etc.
I cleaned out the stove, cleaned the ESP, etc, checked the chain drive, fines box, and everything seems ok.
I cannot think of why it all of the sudden would stop feeding pellets in room temp even set at 90 F.
