Harman XXV troubleshoot
Mikesorel
8
Québec
Hi! My Harman XXV give me some problems.
It's running dirty, not regular (in stove temp mode) and after 2 hours it shutdown. When, it shutdown, the feedmotor Light on the board is ON but the motor doestn"t run.
I made a complete cleaning of the stove and replace the esp probe.
It seems to be a control board failure.
Do you agree ?
Regards.
Mike
Any power outages? Do you use a surge protector?
Auger jammed
Motor died
Vacuum switch died, or got ash up inside it
You can wire auger motor to home outlet and see if it runs.
If so, you can bypass the vac. switch and see if stove operates.
However, it really sounds like a leak, such as you did not get the fines clean out cover back on properly.
