Have some questions about a RSF Delta
continu
2
Northern Wisconsin
Hi there-
After 12 years in a cold house I have found my next project; installing a wood fireplace next year. I grew up with wood being the only heat in my parents house from a Blaze King that was put in in 1980 and is still throwing out the heat, but never considered wood heat for myself until this year. I was more than a little surprised at how far things have evolved over the years. This fall I started looking at wood stoves and my house layout as to what I could do. My opinions of fireplaces have swung 180 degrees and I have my sights on a RSF Dealta 2 fireplace with a gravity feed into the adjacent bedroom.
My current main heat source is a Stiebel Eltron off peak heater which doesn't really work for me as it heats up from 8 pm to 8 am ( the nice warm time of the house) and I normally work most of the night and spend most to the day at home. The electric heater runs 6 ft on the exterior wall of my living room with a depth of just over a foot and a height of 2'-2". The living room itself has a vaulted ceiling on a 6-12 run with 2x12's as the roof structure and the floor has been reinforced for the weight of the electric heater.
This is my plan- pull out the heater and place the Delta with top and bottom vents in the corner on a raised hearth with a cutout in the center where the door is. The hearth and face will be covered in mosaic slate with the cut outs for the top vents. Now here is where the questions for you all come in. I am looking at having the raised hearth at a height of 12" and the Delta unit at 10", does anyone know if this will create problems with the bottom vents?
I hope to put a small mantle on the top of the unit with a step back so the mantle looks bigger without protruding to much in the front, any idea how deep I can make the step back with this unit.
I have looked up as much as I can online but have never seen a unit in person and the closest store is about a two hour one way trip. I am really glad I stumbled across this site and all of you. I am open to all ideas and suggestions about the unit and surround as a whole. Thanks for you time reading this book- Geo
Your post lacking punctuation and paragraph breaks is difficult to read so I could only take away a small bit of it. I can't really make out where the bedroom is in relation to the stove. The gravity vent could potentially put too much heat into the bedroom.
I opted for the central heat blower instead and I also chose to run it backwards, bringing cold air to the stove rather than sucking hot air away. It works very well for me. My class A chimney is chased up through our master walk-in closet upstairs and it throws off enough heat to keep the bedroom just right if the closet door is left open.
WRT stepping back the mantel and chimney breast, the CTC on the class A will most likely determine that. I used all metal studs to build the surround and stepped the chimney breast back 6 inches.
I'm in the process of having an RSF Opel 3 installed. The unit is up and running but the finishing is not complete. I have the central heat blower installed into the plenum which is working to keep the house warm. The living room, where the fireplace is, is the warmest, obviously, and the master BR, always the coldest room in the house, is still the coldest due to it having the longest duct run from the plenum and three outside walls and three good-size windows. The air coming from the register in the MBR is 80F but the room temp is only about 65F. With the geothermal not coming on anymore (and using that evermore costly hydro), it's made us pretty darned happy, though I'd like to see if the system can be tweaked to bring more heat to the bedroom area and a bit less to the kitchen/dining/living room area.
The setup we went with was similar to that in the RSF catalog, pg 15. The unit is set at about a 15-20* angle to the wall adjoining the woodbox. We also opted for the stepback mantle. One thing I'm glad we did was to not go for the clean face option, though we both felt it looked far better in the catalog. With the access to the firebox closed off, how do you adjust the chain controlling the damper or adjust any of the electrical hookup or the blower temperature switch? Just seems that you'd potentially create a huge pickle for yourself by closing everything off. We went with the grates (rather than louvers) to cover the opening.
We did get the thermostat (for the blower) which, since it's installed in the coldest room, means that it's always calling for heat. I think it would be better to skip the t-stat and just put a thermal switch on the blower circuit that kills the blower when the firebox temp drops too low. I intend to inquire about that and maybe remove the t-stat.
I'm using more wood with this unit - about a face cord every 9 days or so (though that's over Christmas and we've been feeding it pretty steady). I anticipate that will drop to perhaps a face cord every two weeks once vaca is over. I was also burning a lot of small stuff (< 2" sticks, 4-5" maple and elm rounds with a light sprinkling of black locust) over Christmas and those stick fires don't last very long. I don't like burning rounds in this unit due to the tendency for them to roll forward (doesn't happen so much in the stove) and bang into the glass and leave coals lying there, waiting to drop out when the door is opened. Splits stay put much better, so I'll probably split everything (within reason) this year. I'm getting huge coal beds which take time to burn down.
Overall, we're very happy with the unit. We're warm in the house now (as mentioned before, still some tweaks needed), we're heating for the cost of some gas and a little electricity (to run the central heating blower plus the furnace fan) and we have a beautiful fire to watch in the evening. I ask you, can life get any better than that?
  • [Hearth.com] Have some questions about a RSF Delta
