I am trying to size my pump but I don't know how to figure out head loss for my heat exchanger. I know that in the description it says it is a 152,000btu and also that the gpm is 15.8. It is a 19x20 water to air exchanger. I am hoping to use one of those small 3 speed Grundfos pumps. It is going to be a pretty simple system with 100' of 1" pex each way maybe 4 pex 90 fittings the exchanger and that's it. I know that I want 10 gpm or less and a delta T of 20 to 40 across the exchanger. I assume since most all factory owb's come with the same pump I will be fine without running the calculations, but I just wanted to check.
