Hello, I need some clarification concerning the hearth extension for a wood insert.
Here is a quote from the manufacturer: "COMBUSTIBLE FLOOR MUST BE PROTECTED BY NON-COMBUSTIBLE MATERIAL EXTENDING (E) 16 IN / 405MM TO FRONT AND (G) 8IN / 205MM TO SIDES FROM FUEL DOOR. IN CANADA MUST EXTEND 18” TO FRONT. THERMAL INSULATION WITH A R VALUE = 1.4 AT A DISTANCE OF 18" FROM FRONT OF DOOR OPENING FOR CANADA AND 16" FOR USA. IF UNIT RAISED 4.5" FROM FLOOR, NO THERMAL INSULATION IS REQUIRED."
My insert will be sitting on the old firebrick which in fact raises the fireplace off the concrete floor by about 5". The hearth will be built at the same height as the top of the firebrick as per the installers reccomendation. Is the hearth considered the floor height or not, meaning do I need to meet the rediculous 1.4 R value? Never thought there was so much thought into a hearth extension, originally I was just planning on a box covered with plywood then capped off with slate tile. Any help is greatly appreciated as this is supposed to be my project for this weekend.
For reference, the fireplace wood insert is a Regency, model Alterra.
![[Hearth.com] Hearth extension [Hearth.com] Hearth extension](https://www.hearth.com/talk/data/attachments/281/281601-4a60ced3c716947f1fb8555a74a966f9.jpg?hash=UeN5P15_t_)
