We just moved into a rental, and it has a Heat&Glo 6000GDVFL insert in it, plumbed for LP, vented. Seems to work (I may be back with wire questions if it does not) but the fiber log set is broken badly, and the technician claims they are necessary for it to function correctly. Dealer price for the "correct" fiber log set is 354.00. Ouch. That's not real doable. Landlord is not willing to pay that, as the house furnace system is new (I have my own issues with THAT too, who designs these things?) so considers the fireplace just aesthetic, and not worth putting money into. The dealer I spoke to said the log set was important because it would soot up if it was not there. As far as I can see, the logs introduce turbulence to the airflow, which would possibly stop soot.
So, question: Can I put generic ceramic logs in this, and arrange them so they cause good turbulence? Would that be enough to make it work close enough to correctly?
It also has two little squirrel cage type fans deep inside for room circulation. They were plugged into the outlet labeled REM (remote, I assume) that is wired to a wall switch (not sure if the other plug inside is wired to the same switch, didn't check that) Is that where it belongs?
The fans pull room air in through the area where the wires and such are, and that whole compartment was just COVERED in dust and dog hair and crud in there, took me a lot of work to clean it. Not sure what someone was thinking designing the air flow channel to be with all of the wires and electrical components....
Question: Can I put a filter on it to keep it from circulating dirt around? I'm thinking the filters that are cut to fit and look kind of like a green scrubber pad (can't find a link right off)
And one more question: Any more advice on this? I have never dealt with one of these, anything I should read or learn to make myself not be a problem in the system? Anything I need to know? Your wisdom would be appreciated!! :D
Thank you SO much for any help you can offer!!
