Hello. I'm a new homeowner with an oil burner and a wood burner. I have no experience with that kind of setup. When using the wood burner, the heat is on even when the thermostats are set to a lower temperature , 60 degrees for example so the temperature in the house is 70. It seems like the wood boiler is overriding the thermostats and is sending heat even though they are set to low. Is that normal ? I would think that it should work the same way as with the oil burner which does not send heat when thermostats are lowered.
