Heat settings
kglassner
11
Pennsylvania
Hey, everyone, recently had a few issues . Lower auger kept stopping. Discovered that it was the motor. It would work intermittently, then stop all together. Swapped top for bottom, figuring it only had to run for a couple seconds at a time it would get met through. Nope. Stopped all together. Bought a pair of motors. Swapped the now top motor, and kept 1 for a spare. Now I only have heat setting 1. Nothing i do will change the feed rate on the top auger. Thinking the board may have gone bad? Any help will be greatly appreciated. Thanks. Ken
kglassner
11
Pennsylvania
I'm thinking, that when the motor locked up and the stove was telling it to feed, it may have burnt something out in the board. Also, it runs for about 6 seconds at a time. Every once in awhile the fire almost goes out. Watching it, at times very few pellets are being fed into the pot. The next minute, there are a normal amount, and the flame is where it should be
johneh
4,582
Eastern Ontario
Make and model of your stove would help us with your problem.
ericofmaine
290
Southern Maine
Try resetting your board. Do a search on here for the procedure. Short of that, its probably your board.
Eric
Reactions: kglassner
kglassner
11
Pennsylvania
Hard reset. Found out it.must have changed back to "a" mode during a power outage. Back on "D" now
Not much better. On heat setting 9 , still upper auger only runs for about 7 seconds and about a 14 second delay between turns. Guess it's time for a new board. Next season..lol. this is only heat for my basement....
