Hi,
I have already had my new Heatilator Constitution unit burning on several days this season but had always used the manual switch to turn the fan on and off manually. I realized today that the (Constitution) manual specifically states that the fan will come on automatically when the fireplace reaches a certain temperature, but you may use the manual switch to force the fan on if you want it on sooner. Out of curiosity, I left the manual fan in the off position to see WHEN exactly the fan would come on...but it did not. I am positive that the wiring to the switch & rheostat is correct (because they turn the fan on/off and adjust the speed properly!) I am wondering if either the temperature sensor is either defective or simply not connected to the metal of the firebox. The problem is that I can no longer open the front access door at the bottom of the unit because the Micore kit has already been installed and the wall is essentially finished except for tile. I don't see any obvious dangling wire, and have no idea where the sensor is supposed to be connected anyway. I would think the sensor is factory installed along with the fans. Any ideas? Any thoughts?
Thanks,
Kev
Thanks,
Kev
