Hello,
I have a Biomass 40 / 500 gallon storage.
I am installing an inground pool (18x36). I live in southern Maine and intend to heat the water in May and late September / early October to extend the time I can use the pool. My plan is to connect a separate Phase III water heater from the storage tank and then circulate out to the pool pump. Please note that heat and hot water to the rest of the house will not be used during the time I am heating the pool.
Questions
1. what size underground insulated piping should I buy. It will be 100 ft of pipe.
2. if I am only heating the pool (not the rest of the house), will this setup actually heat the pool effectively.
Thanks for your help.
Andrew
Questions
Andrew
		 T and flow rate, and with an hx this needs to be considered on both Sides A and B, as well as approach temperature. The "impractical" side of the rating usually is tied to flow rate and
