Yep. I agree. I am assuming those brackets are for the upper bricks and the angle is for the lower bricks. I cannot wait to try out the stove with the fire breaks actually on the interior. I have no doubt it will make a huge difference on how the stove heats the cabin!No, those all look like brick brackets to me. If you look back in this thread to the picture I posted of my All Nighter you can see the upper bricks installed.
I think the angle and brackets are for the fire bricks…. Upper and lower. But I will soon find out when I try to install.Are the upper brackets for a baffle?
![[Hearth.com] Help With Older Stove Model [Hearth.com] Help With Older Stove Model](https://www.hearth.com/talk/data/attachments/293/293913-11e489b6848a6412d9278afba6d774c7.jpg?hash=pdzKWLSR9l)
![[Hearth.com] Help With Older Stove Model [Hearth.com] Help With Older Stove Model](https://www.hearth.com/talk/data/attachments/303/303601-b7003bf4c811143e77d11a2b9a9fe85f.jpg?hash=7oDjOsKsyZ)
Yes, air needs to freely convect behind the heat shield. That's what makes it so effective. Heat can not be trapped behind the shield. It must be at least 1" open on the bottom and the top .Thanks for the informatio, coaly. There is a good inch gap between the back of the mantle and the wood wall. There is also a gap between the cement board and wall. I might need to cut in air vents along the bottom of the wall. Everything sits on a baseboard but I will check it out next time I am up there. Thanks again!
www.hearth.com
Fireproof rug or mat in front of the stove? I doubt it’s code, but better than nothing - especially with a wood floor?You are correct about the front coverage. It is a hunting cabin and I just could not extend any further without creating a tripping hazard for myself and others.
