Hooking up a wood stove in my home?
MNFisherman
2
Minnesota
I have just rented a home that has a chimney. I looks like at some point it had a wood stove since there is a hole for the pipe that has a plug in it. The problem I have is the gas water heater also exhausts out the chimney. Is it ok to reinstall a stove with the water heater and wood stove venting out the chimney?
NO.
Does the chimney have multiple flues? A flue is a lined path through the chimney from the appliance to the top. Each appliance MUST have its own flue. A chimney may have multiple flues. Can you see the top, how many clay or steel pipes come out the top?
KaptJaq
It has only one flue. So the only way to use a wood stove wood be to redirect the vent from the water heater and plug the hole? Kind of a waste to use the chimney for such a small purpose since the furnace is vented out the side of the home. Can you run a stove within the area of a gas furnace and water heater?
@ MNFisherman... I'm from Meenashnowta myself... do you have a furnace in your living room?
and like others said you can mix combustion fuel appliances into one flue
Did you mean can't?
I think there's a couple things.
-Would a landlord be ok with this plan to modify a rental?
-In theory, as someone else mentioned, you could direct the water heater up it own flue and the flue / pipe / liner for the wood gas separately. I don't know anything about restrictions on doing that.
You would have to install 2 seperate liners. Both would need to be stainless due to the heat of the solid fuel appliance.
