I inherited my wood-stove, and the way it's set-up, when I bought this house about 20 years ago. Before then all the places I lived in with a wood burner (cabins and tiny homes) usually had a flue coming out the top of the stove in the back and running straight up and through the roof. Easy-peasy. The stove in this house (Vermont Castings Dutchwest 2461) is centered on hearthstones in front of a mid-house brick chimney. But the cut through in the chimney is off-centered, requiring what I view as an overly complex set of elbows and bends to get the stove pipe up to and into the chimney... (see the attached photos).
I view this with some small concern, convinced that this configuration must cause unruly turbulence as the hot gases wind their way through to the chimney flue, OR am I being overly concerned about this and it actually has no affect on updraft? Just has always seemed wacky to me. Would I be better off moving the wood stove so the stove pipe can be attached using just one 90 degree elbow running into the chimney and attaching to the chimney flue? I could move the stove... it just wouldn't be as nice looking as it is now centered on the hearth stones and centered to the chimney, but if I can improve performance it would be worth it.
Any opinions? Not an emergency... it just kinda bothers me. Thanks in advance...
