How many hours do you get out of a bag of pellets?
mik_kane
274
NEPA Poconos
I did a test the other day with my P61, the hopper was pretty empty and decided to see how many hours I can get out of a bag of pellets. The weather was in the teens to 20's and the stove temp was set at 70 with a feed rate set at 3. The house is 2000 sq ft raised ranch with the stove in the basement. The temp in the upper floor was 66 - 68 degrees. The result of my test was 17 hours with a constant burn (no auto ignite) on one bag of pellets.
So I am asking how many hours do you get on one bag of pellets.
Lately, about 10. It's been pretty nippy. Still cheaper than oil.
I get about the same with outside temps in the 30's. With the big freeze last week (in the teens and single digits) I was getting about 12hrs/bag. If the outside temps are above the mid 40's I can get about 40 hours out of a bag. I heat about 1500 sq ft with about 10% of that drifting to the upstairs via a staircase.
if I run my classic bay with constant fire and on low I think I get around 15 hours. if I run it with the stat set at 70 with out wood heat I get around 23 hours. with the woodstove a bag will last 42-46 hours. my old mp 250 on low was 24-25 hours. it was only constant on. I don't understand how it would vary because the feed system is basically run by a timer. I think anyway. I love that old stove.
It all depends on how cold it is outside. I can burn .5 - 1.7 bags per 24 hours, so, if it's 40F outside, .5 of a bag will last 24 hours. Temp outside as of now is 12F, I am burning 1 bag every 10 - 12 hours with the house at 68 - 72F, heating 1500 sqf with the 25-PDVC at 6 (heat), 7 (blower) in mode 'c'.
Im getting 14 hours out of a bag. 11 degrees outside 71 inside. 1800sq feet of crappy insulated raised ranch.
Depends entirely on stove, settings and for stat-controlled stoves, outside temps and insulation of house. For older Whitfield Quest (no stat, no ignitor so it just burns constantly when lit), set on L-M feed rate, about 18-19 hours. On Med, about 16. On Med-High, about 14. For Quad Mt Vernon AE (stat and ignitor), hard to use more than about 1.3 bags/24 hours keeping room at 73-74 unless temps are in single digits at night and not rising out of low 20s. Most days I get about 24 hours exactly if nighttime temps in the 20s and daytime in the high 30s, low 40s.
Setting on 2, outside temperature in the 40s, inside temperature 62. One bag in 24 hours.
This is on an enclosed porch that is about 400 square ft, glass on 3 sides, insulated ceiling, floor and one outside wall, not airtight, no OAK
Dave
I go about 18 hours on a bag when temps are this low. (15) Stove is on High Low running off my Round Honeywell thermostat set at 70. I have the high setting on 4 out of 5. The air coming out of the stove ranges from 150 to 300 depending whether the thermostat is calling or not.
What is control setting at? Was 4::F last night and burned 1 1/4 bags at 1/2 way...but I am heating 2100 +/-
Basement Harman has been chewing thru a bag and half a day with the Elena bumping for about an hour AM an PM so all total about 64 pounds a day with the temps today of a balmy 3 for a high.
I average 1 bag per day through the entire heating season. It got all the way up to 4 degrees today with a low of -12 last night. 1 bag will last 12 hours and keep the house at 72 with these temps.
A little over 12 hours
When temps are sub 25 I go through a bag every 14 hours. When its 35 or better, about 22 hours per bag.
I alternate between Greene Team Platinum & New England. On average I'm getting nothing less than 18 hours and sometimes 20 with my Englander 25-PDV. Daytime / evening I'm at 4-5 and then down to 2 at bedtime. It's been in the teens for a few days now!!
Downstairs Accentra insert goes through +~- 1.5 bags a day.
Upstairs Veronica goes through +~- 1 bag a day.
2500 square foot bi-level with an attached garage below the bedrooms & lousy insulation.
Likely 4.5 to 5 tons this season.
Still a LOT cheaper than what the electric bill would be. :)
