I was wondering about the correct way to clean the potentiometers on a Hamman P-43. Obviously unplug the stove. Then what? I assume I use electrical contact cleaner? If there's a tutorial on this I missed it, I did look.
Good and bad. These are usually carbon trace pots, and standard DeOxIt can ruin them. Dielectric is an insulator.Be careful with straight electronic cleaner from the automotive store as they do not have lubricants for the pot. They will clean them well, however.
I never cared for years until one time I sprayed some in a switch and worked it off/on and it froze after working it for about 5 seconds. Better thing to use is Caig DeOxit cleaner and lubricant. If you don't want to spend that I've had good success with using isopropyl alcohol and then injecting the pot with a bit of dielectric grease.
Ah yeah, didn't think about that. I guess I have gotten lucky, yet again, by doing it wrong for many years.Good and bad. These are usually carbon trace pots, and standard DeOxIt can ruin them. Dielectric is an insulator.
This is supposed to be good stuff that is safe to use, never tried it, but will give it a try in the future.Deoxit faderlube would be the safest to try, if yours are that bad, I would replace them .
Yep,that's the really good stuff.Ah yeah, didn't think about that. I guess I have gotten lucky, yet again, by doing it wrong for many years.
D5 is good, but things have advanced, as contact cleaners can damage "carbon" potentiometers, and leave them dry. What is now recommended is deoxit f5, specially made for this.I was having problems with the potentiometers on my Accentra FS. In particular, the stove temp/room temp/off switch was no longer responsive. The distribution blower was either on full force of fully off - nothing in between. Also, I stated getting error codes and the stove would shut down, seemingly for no reason.
I used Deoxit D5 to clean the pots and it restored full control.
My Harman has Carbon potentiometers ? Maybe a "Sticky" on this in the Harman thread would be good..D5 is good, but things have advanced, as contact cleaners can damage "carbon" potentiometers, and leave them dry. What is now recommended is deoxit f5, specially made for this.
