how to install class a stove pipe through a tin roof?
RIDGERUNNER30
236
Eastern, Kentucky
Hey guys I'am tiling my hearth pad rigth now and getting ready to buy my alderlea t-6 wood stove , my question is i will be installing a double insulated class a pipe, my pipe will go threw my second story closet and i plan on building a chase to enclose the pipe with the required clearances .my question is how do you seal around the the chimmey once it goes threw the roof, I see how people do this with a shingle roof, but i have a new metal clored tin roof what are your guys thougths. do you buy some kind of caulk sealant to go around the pipe to prevent water from leaking threw my roof.
i'm with ridgerunner. i have looked for this from time to time and cant seem to find anything.
mike
Selkirk has a rubber boot flashing kit.
(broken link removed to http://www.selkirkcorp.com/WorkArea/downloadasset.aspx?id=1608).
PM Hogwildz for the full details on the best way to do this. He's the expert roofer.
Didn't japipe do that last year? Pretty sure his post had plenty of pics too? Also he installed a device to divert the ice around the chimney pipe...info could be of use to RIDGERUNNER30.
I have installed metal roofing on many homes. Around large masonry type chimneys we used a colored flashing from the metal manufacturer and sealed around that with a clear silicone caulk. Around small protrusions such as bathroom vent pipes, gas vent pipes, electrical installations, and small chimneys we measure and cut the metal to fit very tightly 1/4" or less then seal around that with clear silicone caulk.
Many manufacturers make high temp silicone rubber roof flashings for ribbed steel roof penetrations. If you have a lumber yard or hardware that sells the roofing in your area they should have a source. They are not inexpensive but they do the job. They have a "lead" edge that is formed to the roof and sealed and screwed down.
In addition you may want to build a diverter or “cricket” on the up slope side to turn water and snow away from the penetration of the roof caused by the chimney.
If you cant find information drop me a note and I can call my supplier and get the name of the product they carry.
Garett
How close is your chimney to the peek of your roof?
What I did on with my chimney, and skylights, is to lay another sheet of the metal roofing over top the chimney flashing and and metal roofing and slide it up under the ridge cap. That gives you a continuous seal from the ridgecap down and over the metal chimney flashing.
Of course this may not be practical it all applications, but if you chimney is located close to your ridgecap it is the easiest and the most water proof, you are not relying on caulking which breaks down with time and tends to hold dirt and debri.
