Husky 371xp problem
jwalter04
43
Connecticut
My 371xp started acting funny today. Halfway through a cut it will peter out and die. If I let off and allow it to idle for a second it will rev back up but eventually peter out and die again. After it dies it will start back up with one pull, and run like there was never an issue, until you start cutting. Spark plug, air filter, and fuel are all new enough to not likely cause a problem. This this hasn't given me one problem in the three years I've owned it. Didn't want to start tinkering till I got some advice. Any thoughts?
Try loosening the gas cap when it begins to die.You tank vent could be pluged
Reactions: StihlKicking
Yep, along these same lines, it sounds like fuel starvation. A leak in the fuel line could allow it to suck air instead of fuel. A leak in the impulse circuit or a stiff pump diaphragm could prevent the carb from pulling in fuel. Debris clogging the filter screen inside the carb might restrict fuel from making it to the metering valve quickly enough.
These two posted what I was gonna say, probably an air leak somewhere.....
