Ok guys, I've got a diagram here for you to follow my logic on...
For Controllers I'm thinking of using these controllers on eBay: (broken link removed)
They seem to be quite popular with the homemade espesso machine crowd and get good reviews...
Now, here is my idea: Statements are numbered...
1: If temperature A is greater than 400F then the fans on the stove will be slowed to half speed to slow down combustion and allow the water more time to absorb from the exhaust.....
2: If temperature A is less than 225F then the water pump will be shut off to allow the stove to catch up and keep the gases from condensing in the heat exchanger..
3: If temperature B (water temp in heat exchanger) is greater than 175F then the water pump will turn on to circulate water.
4: If temperature B becomes greater than 190, then the fans will be shut down to protect from boil-over. This will override instance 2, so if temperature a is less than 225F, but temperature B is greater than 190, the pump WILL still run and the fans are shut down. It's more important to keep away from the boiling zone than to have exhaust gases condensing.
5: If temperature C becomes lower than 350F then the entire stove (fans and pumps) will be shut down. This is to keep a bed of coals in the stove for easier start up on next load. There will be a latching relay circuit attached to a "start" button that will override this control to allow stove to be started.. Once temperatures exceed 350F, then the start circuit will be canceled and stove control will be taken over by the end-of-burn circuit (Temperature C)
What do you guys think? Do I have my temperatures right and all? I'd appreciate any feedback you all have.
 LOL!
