Are you throwing money out the exhaust pipe? I.E., will the exhaust temp be higher when not using the noise maker on a gas stove where said noise maker was an add-on option?
Inside Guy said:I agree with R&D;Guy, for the most part. It would have to be a very sophisticated air exchange system for a "add on" blower to reduce flue temps. It doesn't hurt to add a blower, they do help distribute heat, reduce surface & wall temps, etc. However, in terms of increasing the efficiency rating (AFUE) of the fireplace, adding a blower does very little to reduce exhaust flue temps.
as/gds28.html)tubbster said:Inside Guy said:I agree with R&D;Guy, for the most part. It would have to be a very sophisticated air exchange system for a "add on" blower to reduce flue temps. It doesn't hurt to add a blower, they do help distribute heat, reduce surface & wall temps, etc. However, in terms of increasing the efficiency rating (AFUE) of the fireplace, adding a blower does very little to reduce exhaust flue temps.
So actually, you are not agreeing with R&D;at all? He states a 10 - 25% change in efficiency, which is pretty significant. Anything that would reduce exhaust temps would affect afue.
I am really surprised how hot the outside coaxial pipe gets, and that is of course the intake air! It is too hot to touch. I have a feeling the AFUE of my stove is *MUCH* less than that stated in the brochure!
On your standard 36 DV unit, a blower doesn't do much, that is in terms of reducing flue temps. Now, there are so many made-up marketing efficiency numbers out there it's hard to keep track of them all. As we all know, AFUE can be manipulated to the best case vent configuration to get the best number. Yes, P4 is much more strict than AFUE, but even that data can be manipulated.R&D;Guy said:Inside Guy said:I agree with R&D;Guy, for the most part. It would have to be a very sophisticated air exchange system for a "add on" blower to reduce flue temps. It doesn't hurt to add a blower, they do help distribute heat, reduce surface & wall temps, etc. However, in terms of increasing the efficiency rating (AFUE) of the fireplace, adding a blower does very little to reduce exhaust flue temps.
I may be missing your point, but if you are increasing the amount of heat exchanged into the room at the same input of BTU's, then by the laws of thermodynamics you would be increasing your efficiency resulting in a lower flue temperature (less heat loss out the flue). Everything has to add up to 100%.
tubs - the AFUE & Steady State ratings are not policed by any agency, or required to be witness by a independent lab. As I've joked before, the test is likely run by a drunken sailor and a salesman.
If the appliance is also listed in Canada, then it must go through a Canadian efficiency test which has to be witnessed by an independent lab. These tests are not perfect either - for example, you are not permitted to use a blower during these test, but like I said unlike AFUE and Steady State, this test must be witnessed by an independent lab and are therefore more likely to be accurate.
(broken link removed)
I don't see your GDS25, but the GDS28 is listed at 57.4% efficient. I don't know how close the 2 are in design, but look on Napoleon's website and note that they claim the GDS25 is a whopping 86% efficient. LMAO! Drunken sailors, and salesmen I tell ya.
(broken link removed to http://napoleonfireplaces.com/Stoves/stovesas/gds28.html)
Inside Guy said:First, I just love talking fireplaces; I was so pumped to find this forum!
As the second law of thermodynamic states, there's no such thing as free energy. If you're not reducing flue temps, your not reducing heat loss through the exhaust.
tubbster said:Would one get better numbers running at minimum throttle?
EDIT: I see the energuide number is what R&D;was referring to. They seem to go from a high of 80 to a low of 51. 64 is right in the middle of the pack.
This one seems to be leader of the pack at 80.
It looks fairly conventional!
Off the top of my head I don't have a good answer either. I'll dig through a couple project files and find out.R&D;Guy said:tubbster said:Would one get better numbers running at minimum throttle?
tubbster - The Canadian efficiency test does test both max and min BTU's. Why they only list high I don't know, but if you email them you should be able to get the info.
Maybe Inside Guy can talk about his experiences, but off the top of my head I don't think I've seen more than a few degrees of increased efficiency on low. I don't believe I've ever seen a test where a unit was less efficient on low.
