The unit is a Jotul Katahdin GI450DV. It is installed in a brick fireplace with dual liners 20 ft up throught the roof to a high-wind style cap. It was converted at install to LP with the supplied orifice. Sometimes when the thermostat calls for heat, the valve opens, gas flows around the burner, but the flames stay a transparent blue, dance around the burner, then lift off the burner completely and die. The pilot also goes out, so a few seconds later the valve properly shuts off. This happens less than 10% of the time. There are other times you can see it struggle to light. The flames are extremely tall and thin for a few minutes, then settle down to normal.
I've read the different opinions here about opening the glass to see if it will relight, to test for a vent problem. If this sounds like a lack of combustion air, should I try a less restrictive cap? I have the can shaped one, with vertical openings around the cylinder.
Thanks for any help. 13 below zero this morning, and disappointed to see it out again.
