I'm finally getting around to installing my Morso 1410 Squirrel and Duravent Class A chimney. I was all set to go back in April, but hurt my back. It seemed prudent to heal completely before doing any climbing, lifting, and twisting.
It's been awhile since your advice in April. A refresher:
The install is in my sunporch, glass windows all around from about 34" up. I'm going through the wall so I don't have to cut an enormous hole in my painstakingly-restored 91-yr-old T&G beadboard ceiling. Yes, most of you guys told me to go through the ceiling and heavily-insulated attic. I know the wall install will make it draft more poorly. Still, when California bans wood-burning altogether, I can repair the hole in the wall much more easily than a hole in the ceiling.
To date:
I did manage to get the wall thimble installed, despite my back injury.
Today's question:
When I connect the sections of double-walled stove pipe to the stove, and then to the Class A Duravent at the thimble, do I need a high-heat mastic or sealant? The stove pipe will be screwed together, but what keeps it from leaking smoke and gases into the room? Also, the instructions on the Duravent say to just twist and lock the pieces together, with screws optional. What are your thoughts on this? And, again, should I be using mastic or sealant?
Thanks to anyone who is answering today. I know you'd rather be outside!
To date:
Today's question:
