Hi Folks,
In another thread, BeGreen posted:
[quote author="BeGreen" date="1292853494"]
From the Englander 30NC manual: "The design of your new appliance is such that the exhaust “smoke†is now at lower temperatures than in the past, therefore requiring proper chimney size to give adequate draft. If your chimney is too large, the heater will have a difficult time raising the temperature of the flue enough to provide adequate draft, which can cause a "smoke back," poor burn, or both."[/quote]
To avoid threadjacking, I'm posting my question here:
Is a 2" diameter chimney oversize (8" versus 6") a significant issue with a well insulated pipe--like an insulated liner or Class A in an insulated chase?
Asked another way,
Would a well-designed 8" chimney (straight, insulated, tall) likely cause significant performance issues with a 6" EPA stove, with it's lazy, cool exhaust?
Hint: I'm hoping the answer is "no".
In case you're interested, here's my motivation for this question.
Pending investigation of the new Woodstock I'm leaning towards a Blaze King King. The Woodstock requires a 6" chimney, the King an 8". I'd like excellent performance with whatever stove I get, with the flexibility to run other stoves in the future. I have to decide before putting in my chimney.
After much pestering, investigating and calculating, and no manufacturer response to my technical questions, I've come to the conclusion that running an 8" stove on a 6" chimney is safe, with the chief downside being increased smoke spillage on reload, and possibly reduced maximum output. (If anyone has more insights into that, please share!)
That has me leaning towards biting the bullet and putting in an 8" chimney as the best bet against future needs. But if an 8" will probably perform poorly with a 6" stove, I want to take that into consideration.
I know it's hard to predict hypotheticals, but I'd appreciate any insights!
Asked another way,
