Above is a link to show the video of my situation and this is my first stove so I’m unfamiliar.
Pellet stove was freshly installed this week and today I decided to do a test run to see if there were any issues before it gets cold.
Now I understand that there is some “burn off” and I ran it for a bit after install and it smelled bad. Not like smoke, more like a burnt plastic.
It appears there is smoke coming out of the exhaust pipes from the stove to the wall. When I ran it today it’s still the burnt plastic smell, definitely not a smokey smell.
Asking around some people are saying it’s an issue, others are saying it’s normal and the “leaks” will seal themselves after a few runs.
I called the installer and he said the latter. Said it wasn’t uncommon and if it was an issue after a few runs he’s come back out.
One thing I need to disclose is when they came to install they did not bring what we discussed to put underneath the stove. Was discussed and I decided I would slide some tile underneath it post install since it’s sitting on a wood floor. Could that adjustment be causing the leaks because it’s now not the same height as when installed?
And help and advice would be greatly appreciated. I’m a newbie so I may be overreacting but I don’t want to fill my house with combustible gases and die. Thank you!
