Hello,
Came across this forum when trying to troubleshoot my Whitefield Profile 20 Pellet stove. I bought a house last year which came with a pellet stove. it worked fine for a month, then started having issues dropping more pellets in during the demand phase. worked fine during start up. I replaced the high limit heat switch and i cleaned off the eye, and pellet stove is working perfectly.
Now for my new issue:
while cleaning it, i noticed that the hose on the vacuum switch was kinda not on all the way, so i pushed it back down on the switch side so it was on there snug. Now my pellet stove will not drop pellets at all. the auger will not move. based on the wire diagram, this is working as intended as this switch is in the circuit for the auger motor. if i remove the orange silicone tube from either the vacuum switch or where it connects to on the back by the blower, the auger starts moving with no issue. I completely cleaned my entire pellet stove and there are no blocked ports or fans, but i cant figure out why it is causing positive pressure ( i think its positive pressure because if i disconnect the hose, i can feel air being pushed through the nipple that the hose connects to).
any help will be appreciated!
