Hey all, Merry Christmas! I wish I had better things to do than post here, but here I am.
My stove is acting up again. I'll try to explain best I can, but it won't be easy.
Currently my feeder won't feed when I try to start my stove as I normally would.
However, the feeder does work on test. But, sometimes when I try and 'test' the feeder a few times, it will actually start feeding as it should, but then it won't ignite
My stove was giving me issues a few weeks ago and I was able to fix it by cleaning out the exhaust and fines box. Then my stove worked and stayed running for days, but then I noticed that it wouldn't get as hot as it would before (up to 80 degrees in the living area) and was only getting to around 70, even with the stove temp settings maxxed out. It seemed like my feeder wouldn't keep up as it normally would....the fire is always very low into the burn pot. I raised the feeder settings, went to bed, never really noticed if it got warmer, but went through an entire bag in 10 hours. Once it ran dry, here I am not able to get it started again
Any ideas why the feeder works on TEST, but not when starting up? If I could figure this part out, then maybe everything else might make sense.
Merry Christmas everyone!
