King 5502m
Mkhimmy
2
Pennsylvania
King 5502m starts up fine however the room fan does not come when stove gets hot. When I hit the power off bottom then the room fan comes on. Is this a bad temp sensor?
begreen
Mooderator
Staff member
Nov 18, 2005
101,053
South Puget Sound, WA
Is this a pellet stove?
Jeremy6500
360
Indiana
I have a 6500 and the room fan is turned on by a flue gas temperature sensor. I haven't looked at mine in great detail, but you could probably jump the sensor and see if the room fan comes on . If it does then it could be a bad sensor. I would also make sure the exhaust is really clean. On other stoves I have had enough ash build up that it insulated the sensor to the point where it wouldn't register a flame.
Providing some history on the stove would help troubleshooting too.
Have you looked for your technical manual in the USSC Troubleshooting sticky thread at the top of the forum? I think there is a self test that you can run.
tlc1976
1,305
Northwest Lower Michigan
I agree, likely the low limit thermodisc either bad or coated with soot. Unplug it and jump the wires together and see if the room fan runs. For testing only. If you burn with it jumped and the fire goes out, it won’t know it and will keep feeding pellets until the hopper is empty.
Mt Bob
4,422
park county montana
I would say you have a control board problem. Try the fan adjustments instead of the power buttton. Also,would not hurt to check the fan connections,from the board to the fan.
