Laddomat Pump Replacement
McKraut
349
South Central PA
I am trying to get the boiler up and running for the season. I had a very late start because of some other projects on the farm. When I first fired up the boiler, I noticed that the circulator wasn't, well, circulating. I pulled it off the Laddomat to verify that it wasn't stuck, which it wasn't. After researching on a few other forums, I read that it is the pump, not the capacitor, that has gone bad.
I am looking for a replacement circulator for the Laddomat. The pump is a WILO RS25/7-3-P. I have read some older posts and I know this will be difficult to find. I have not found it anywhere in the US and have only found 1 location on the internet that sells it. That is in England and with shipping it will cost about $360. I have reached out to several supply companies, WILO, Termovent, and individuals and have a received only a few replies, but no possibilities. For that cost for a pump, I am considering taking out he Laddomat and replacing it with a Caleffi, but that is my last choice.
Does anyone know where I can get this pump? If I can't get this exact model, are there any other WILO pumps that will perform as the original. I would be willing to switch from 240V to 120V if needed. I listed the specs at the end of the post.
Thank you for any help offered!
Bob
Star-RS 25/7
Data sheet
Materials
  • Shaft
1.4034, X46Cr13
  • Pump housing
5.1300, EN-GJL-200
  • Impeller
PP-GF40
  • Bearing material
Total carbon
Operating data
  • Max. fluid temperature T
110 Celsius
  • Min. fluid temperature T
-10 Celsius
  • Maximum operating pressure p
10 bar
Motor data
  • Emitted interference
EN 61000-6-3
  • Interference resistance
EN 61000-6-2
  • Mains connection
1~230 V, 50 Hz
  • Power consumption P1(Q=max.) of selected impeller * number of pumps P1
147 W
  • Max. speed
2700 rpm
  • 0.6 A
  • Protection class motor
IP44
Installation dimensions
  • Pipe connection on the suction side
G 1½
  • Port-to-port length l0
180 mm
Information on placed orders
  • Net weight, approx. m
2.80 kg
  • Brand
Wilo
  • Product description
Star-RS 25/7
  • Article number
4037310
I'm wondering what you ended up figuring out about a motor replacement for your laddo.laddomat?
Ty,
Erin
