Really weird. They glow very faintly even when the switched outlet is off. I checked voltage at the outlet between and got 47 volts from the hot leg to both ground and neutral. I also got around 40 volts in three others switched outlets on different breakers, although I didn't see lights glow when I plugged them in (it is daytime though). An outlet tester checked out, no voltage between neutral and ground, checked tightness of neutrals in box. What is interesting is that voltage persists even when I totally disconnect the switch! That's where I'm at now.
Could there be a generic issue with the outlets? Inductance in wire run?
