I am out of gel and sanitizer, what else can I use to light these pellets.
And my blow torch won't friging lite.
[emoji20]
[emoji20]
I use a propane torch.
Most households have far more flammable things than one thinks
Liquor cabinet with anything over 140 proof?
no danger of you freezing with that antifreeze flowing through your veinsSacrilege! I'd rather freeze to death!
No need to soak them at all. I used the method for when I was servicing corn stoves. Just enough fuel to wet the pellets. A tablespoon is about enough to treat a cup. I carried them ready to go and could get the stove up and ready to fine tune in very short order BUT the use of flammable liquids in a warm or hot stove is a big hazard. Fuel oil, kerosene, lamp oil(citronella torch fuel is my favorite) are about the same thingI've tried a method using kerosene - similar to charcoal lighter fluid. I've soaked the pellets for 15 minutes in it, then strained them out and put them in the fire pot. Starts up and they'll burn fine. It's faster than starter gel or hand sanitizer.
