LINEAR EXPANSION ?
rustynut
377
mid mich
I've seen these guys put a steel rim on a wooden wagon wheel. They heat it up and slip it on, then quick cool
I guess to keep from burning the wooden wheel any more than necessary ?...Was wondering how much expansion to expect and how to calculate it ?.......any one know about this ?
thanks
rn
I have no idea but whatever you're making sounds cool and I want to see pics.
Used to do it to bearing races on shafts, heat up race, slide it on shaft and once it cools, it isn't coming off.
just got to wondering just how much expansion would result when heating up a piece of steel.....have done the race thing b4 and know it works.
Have to go thru that formula and have a look......thanks.......rn
I deal with this at work frequently, we do rubber molding.
If you put a room temp metal part into a hot mold(300::F) it will expand, and you need have enough clearance so it will not
get stuck.
example:
Take a 3 foot dia (36 in) steel wheel rim, heat it from room temp 75::F to 1000::F how much does it grow?
change in temp 1000::F-75::F=925::F
Thermal Expansion Coefficient of: steel 7.3 (microinch/(in oF)) or 0.0000073 inch
[Hearth.com] LINEAR EXPANSION ?
L = Linear Expansion
L1 = Initial Length
= Coefficient of Linear Expansion of the Material
T1 = Initial Temperature
T2 = Final Temperature
0.0000073 inch x 36 in x (1000-75)
0.0000073 inch x 36 in x 925
=.243
So the rim will grow by almost 1/4 in, 36.243
their is a use for all that math!.........that's what I was looking for......thanks......rn
WES999,.......looking at your formula I have a question.......wouldn't the L1 (initial length) be the circumference ?
pardon....... I plugged in the circumference and worked thru only to find your answer....... thanks......rn
handy site.........thanks
