liner advice
chammy
15
southern il
going to install a liner i have a 6.5x11 id clay rile chimney... 6 in round with insulation wont fit can i "ovalize" a flex liner to fit or should i buy the high dollar already oval piping. thanks
We put in a flex king pro with the smooth interior wall no insulation and it works great and it's a breeze to install. We just did our first clean after two months and we got about a coffee cup full of crap out of it when we ran the brush down it a few times.
that and i can get a 40' roll ov 3200 degree half inch insulation from my buddy at the mag foundery for 50 bucks .. would like to utilize that route cause its a lot cheaper but deffinatly open to suggestions
I've read some threads on here where people have had luck ovalizing their own and others that went a little far and tore the liner. Maybe at that chimney height someone that knows better than I can chime in and see if you could go with 5" round.
What is the price difference between the round and the oval?
With that length, if it were me, I'd be putting a 5.5 inch liner in.
If it is an interior chimney, and the chimney is in decent shape, I wouldn't put insulation around it and try it for a year then decide if I want to insulate.
If it is an exterior chimney, then I would pour thermix around it.
pen
I have the same size clay liner. I ovalized the 6" liner down to ~4.75" and used wrap insulation. The liner dropped right down 27' feet, no problem. I was concerned that it might affect the draft but the draft is super. Well worth the time and effort for a quick installation without the cost of pre-ovalizinig.
The only reason I worry about ovalizing myself would be if you run the risk of separating some of the seams. I like the 5.5" liner idea though.
I have a 30' chimney also, and used a 6" flex liner. I bet I could have used a 5" liner and still would be fine. Right now Im trying to slow down the draft..
i just didnt know if since insert has6" connector if i had to stay with that ... if not ill go with 5 or 5.5 and problem solved
chammy said:
musta jacked up my math i come up with needing 518.8 bags of thermix
That would be to fill his house, not his liner. :-S
The volume of your chimney is 11*6*360=23760 in3. The volume of a 6" liner = 3.14*(3*3)*360=10173.6 in3. 23760-10173.6= 13586.4 in3. Converting that to ft3 13586.4*0.000578703704 =7.8625. Each bag of thermix covers about 2.5 ft3 so you would need about 4 bags (3.14 )bags. I would have to do the math but would thinkif you are using thermix I'd use the larger liner. Insulatiion wrap I'd use the smaller liner, if it will fit.
