OK, although I have been steeping myself in the collective wisdom of the Boiler Room for 2/3 of a year, my first burn was only mid last week, so my learning curve on the "practice" is steeper than on the theory (what's that wonderful quip - "In theory, there is no difference between theory and practice. But, in practice, there is.")
I am fantastically happy with my unit (Econoburn 150) even though there is more to do on the final configuration of the install, as well as more to learn as to how to run it at its best.
one of the things that I am running into is that, sometimes, once I have secondary combustion going, but pause the unit to load a piece or two of wood, and then go to close the damper and turn the blower on again, it does a "backfire" -- there's a "rooowhoooomp" sound and you can hear the barometeric damper clang, and also hear pressure push back out through the intake fan.
I typically power down the fan, and then open the bypass door as the fan is winding down to zero RPMs; then I load the wood. Then, to power back up, I have tried both starting the fan first and then soon after, closing the bypass, and also the reverse.
I will sometimes briefly open the lower door to let some updraft and flame through the new wood, as this seems to get the whole thing into a happy resumption of gasification sooner than if I just throw new wood in and recommence the burn
Barometric damper is set to 0.03 " water column, per Econoburn specs of more than 0.02 and less than 0.05
Chimney can draw like crazy if it is not being held back by the barometric damper- so I do not think I am dealing with any problem with a restriction in the flue.
Thanks, everyone, as always.
Trevor
Trevor
