Looking for a Quadrafire Classic Bay Pellet Stove Replacement Exhaust blower? Orig is a FASCO.
Don2222
9,126
Salem NH
Hello
Looks like an older Fasco where you can see the shaft turning at the very end. I used 3-1 oil on it to quiet it down.
If I need a new exhaust blower then what is the cheapest way to replace it?
Maybe someone at Fasco Distribution can xRef it?
http://www.fasco.com • 800-325-8313 • fax 800-352-7207
The specs are FASCO Model 702111383 115 VAC 0.6A Type U21B 60 HZ 3,000 RPM
Quadrafire Part # 812-3381 with a diameter of 5 inches between the mounting screws. See red arrow in pic below:
Mountain View Hearth has it for $330 !!! but I do not need the housing just the FASCO blower motor and maybe fan blades??
http://www.stove-parts-unlimited.com/Quadra_Fire_1200_Exhaust_Blower_p/812-3381.htm
The diameter of the motor casing is 3.3 inches
The distance between the 3 holes shown by the blue arrows are approx 2 and 3/4 inches
Looks like a D202 in this FASCO pdf?
http://www.fasco.com/documents/pgs022-030.pdf
  • Looking for a Quadrafire Classic Bay Pellet Stove Replacement Exhaust blower? Orig is a FASCO.
Hello
I am still looking if I can find something cheaper but this is better than buying the housing and all!!
Got a nice response from Jason Munson. He is a good guy for pellet stove parts.
See >> http://www.pelletstovepro.com/
I left a message of what I needed.
He sent email saying this will fit!! Has Fans Blades and is cheaper at $247.00
3-1/4" Diameter Motor Housing
4-3/8" from front to back
To: Don2222
Sent: Sunday, February 26, 2012 7:15:26 PM
Subject: Re: Contact Jason Munson
Don,
This is what you need.
http://www.ebay.com/itm/Quadrafire-...892?pt=LH_DefaultDomain_0&hash=item20b5e4bbf4
Jason
smoke show said:
http://lmgtfy.com/?q=Pellet+Stove+Blower+Motor,+1/14hp,+3000RPM,+0.6+amps.+115+Volt+
Thats the same blower from the thread I posted (Rotom).
I bought one. Sounds different (different type of motor) but works the same. Much cheaper than stock (by half).
smwilliamson said:
You are looking for a Fasco A082, find it here, http://www.emotorpro.com
$115.00
Hi Scott
Here is the same FASCO A082 for only $90 at CSH. I bought from them before and they are good.
However the specs are a little different 2800 vs 3000 RPM. Close enough?
ASIN: B000BT8TVM
Item model number: A082
http://www.cshincorporated.com/product_info.php/products_id/3462
A082 Centrifugal Blower
75 CFM
115 Volts
.95 Amps
2800 RPM
Shaded Pole
3.3" Diameter Motor
Wheel size 4-3/4" x 1/2"
1 speed
2800 RPM @ free air
.95 amps @ free air
NOTE: fits Breckwell, Whitfield, Travis, Lopi, country, Glowboy, and many others, some simple modifications to this unit may be required for bolt up pattern.
Cross References:Aladdin hearth 7021-10215 7021-10511 7021-10725, Aladdin Steel 7021-7856, American Energy 7021-8286, APR Industries 7021-10216, 7021-9081, Blowers 7021-8165, Burgess 7021-7908, Earth Stove (hearth trends), England Stove 7002-1942, 7021-9667, 7058-0225, Even Temp 7021-10327, Freeland Flame 7002-2411, Glo King 7021-8215, Grainger 7021-7290, Heathland (auton con) 7021-8129, Heat Tech Industries 7021-8855, National Steel 7021-7372, 7021-11027, 7058-0064, Pyro 7021-7757, Sherwood (enviro) 7021-7850, Travis 7021-7586, 7021-9037, 7021-9038, 7021-9778 U.S. Stove 7021-11358, Waterford Stove 7021-10309, 7021-8293, 7021-8030, 70218030 7021-8786, 7002-1942, 076002B England stove (note appears slightly different tab mount, have to reuse the discharge spout), 7021-9527 Earth stove (hearth trends), Harman P2
Hello
Looks like this FASCO Motor has the Exact Same Specs and size plus is Super Quiet!! I wonder if that is the same as the FASCO A082 it does not give any numbers!!!
http://www.amazon.com/Whitfield-Pellet-Exhaust-Blower-Gasket/dp/B005DTDOG0/ref=pd_cp_hi_1
Product Features
Voltage: 115 VAC 60 Hz
RPM: 3000 / Amps: 1.5
Motor Protection: Thermally Protected
Termination: 2 wire with AMP terminal
Warranty: 1 Year
ASIN: B005DTDOG0
Product Description
Ultra Quiet Engineering - If you want Peace and Quiet with Low Vibration...You found the right motor. This motor is so quiet; you won't know your stove is on. Estimated Lifespan: 15-20 years. Fasco uses the highest standards of engineering with parts calibrated within 1/10,000th of an inch. The room for error is so small is has to be checked using a microscope. Your new motor is designed for Variable Speed which requires high quality electronic components not included in other motors. High temperature rubber bushings and washers are used to Damper Vibration. A FREE high temperature micro fiber low vibration gasket is included with you motor to insure you have the highest quality item available anywhere. Go Green. In accord with new environmental standards your new motor is more efficient so it cost less to run.
Don,
What matters after matching up the motor specs (so you don't fry your controller) is the impeller.
The unit you have as Whitfield .... w/Gasket is what I replaced my dying combustion blower with. It is also uses much less electricity than is stated in the ad.
I'm on a hunt for high efficiency electric motors, my goal is to reduce the power requirements of my pellet stove.
