I couldn't really find a forum board that fit exactly, so I thought that the "Central Heating" theme seem pretty close...
As mentioned in the thread's title, we wish to replace the 2nd Generation Nest "Learning Thermoststat" that came with the place and, quite frankly, is driving us a bit nuts. It started acting up by going blank, so I did the obligatory web searches and found out that it didn't have a dedicated power supply wired to it, so I purchased an external transformer and wired the appropriate AC voltage to it. Well, that worked very well -- for a while. At present, it displays a blinking red indicator, above the adjustment ring, and occasionally displays a "The thermostat is restarting. Back in a bit" message.
UPDATE: So I just ended a fairly lengthy call with a tech at Google Nest -- who, judging by the sounds of the birdies chirping, was working from home -- and, in the end, he was only able to tell me that the thermostat is out of warranty.
My main concern is with getting a thermostat that reads and displays temperature and turns the boiler off and on in accordance with our desired temperature settings: and not so much with finding a microprocessor controlled "smart" thermostat that one can access via a network.
So, if anyone reading this has experienced issues with their Google Nest thermostat, especially if it required a replacement, I'd really appreciate recommendations for a good [reliable] replacement.
Thank you kindly for your attention ~ Okla
