Like many others I've been reading the numerous threads and have gotten a wealth of information from all the input. Thanks to the many who take the time to provide insight and help to the many questions that we less experienced ask.
My woodstove experience started 13 years ago when I went to a friend's house one night and was just amazed at the amount of heat that was coming from his Buck Stove insert. Could not believe he was essentially heating the entire house from this simple addition to the fireplace. I had recently moved to a ranch house with 2 fireplaces and was now determined to get an insert. Found a Regular Buck stove (26000) used for $100. Bought the glass door inserts and with the help of 3 friends moved it into one of my fireplaces back in the family room. 5 years later that friend that I had visited originally was moving and needed to get rid of his stove, so I got a 2nd Buck stove for free and put it in the other fireplace. I live in Virgina and thanks to several Hurricanes, I have had a steady supply of free firewood and have never had to pay for any yet. I even invested in a splitter this past year instead of continually renting one. I've mainly use only the one stove in the family room to heat that end of the house while still paying $3000 a year for oil.
But, the more I've started to learn the less I'm comfortable using this slammer type woodstove as the amount of creosote in the fireplace is substantial as my chimney cleaner continues to tell me. So I've finally made the decision to upgrade to one of the new EPA stoves and install a liner in the chimney.
My house is a 2600 sf ranch which is shaped in a flat U. The problem being the family room is at one end of the U and the master bedroom is at the other. Chimney is on the exterior wall, more bad news. This was always a problem with the Buck Stove cranking out the heat at one end and chilly at the other end. Being a mechanical engineer, I installed an inline fan in the attic last year and ran insulated flex ductwork from the ceiling diffusers in the family room to the back bedroom. This worked pretty good as I was able to blow 80 degree air into the back of the house, but I still wasn't comfortable doing overnight burns with the Buck so I wasn't able to make it entirely successful.
My dilemma is that I know the smart thing to do is to buy 2 smaller stoves to better distribute the heat, but one it costs more money and two I now have a pool table only about 5 feet from the hearth in the living room so I obviously no longer use that stove.
So while I have learned that I should try to maximize my firebox size to get a longer burn time, I question what size insert would fit in my fireplace. The fireplace opening is 26" high and 17" deep and while most of the inserts I'm looking at will fit in the opening, it seems to me like you need at least 3" clearance at the top to be able to connect the liner to the stove. Yet the stove specs often say minimum opening size is only 1" or 2" larger than stove. How can you get your hands in to connect liner with only 1" clearance?
My chimney cleaner is also a friend and is going to help install the liner and stove. He is only charging me material cost for the liner. I'm trying to keep the stove cost less than $2000 and am looking at the Englander 13NCI (really want an American made stove) as well as the Osburn and Drolet lines. My concern with the Englander is whether the smaller insert will be able to heat the one side of the house and still provide heat through the attic fan to the back bedrooms. So I'm leaning toward a larger stove as long as it fits. Sorry for the long thread and thanks again for any advice.
