I'm planning on building a 240 square foot tiny home this summer that will be well insulated in climate zone 7. I have a TON of wood and love burning.
I feel as if this will be an impossible task given that I will probably roast myself out. I also plan on putting in a mini split heat pump that will be rated to at least 5 degree F. Ideally I'd find a wood stove with a low BTU output but will probably have to settle for a propane vented heater. Unfortunately all softwood which doesn't help.
In my research, I believe catalytic is the only way to go here and the lowest BTU output I have found so far is the BK Boxer 24 coming in @ 9589 BTU/Hour on low. I'd love to have a firebox that could sustain an 8 hour burn or at least leave some embers to start it again.
Any other LOW BTU contenders I should look at?
EDIT in looking at the EPA website I have found these:
- Woodstock 202 Palladin/204 Keystone - 7606
- Blaze King Ashford/chinook/sirocco - 8900
- Regency CI2700/HI500 - 8292
NON CAT
- Morso Jernstoberi 2b Standard - 6959
- Woodstock - ideal steel - 9324
NON CAT
I almost got a Dwarf 5 kw for our place. Glad I didn't. I found the Jotul used for cheaper. It looks way better (as does the Morso) and takes decent size wood. Since our place is log construction, it eats up the heat. Once the place is warm small shorter fires keep it that way due to the mass.
