Lubrication Magnum Baby
GMadd
115
Highland, NY
So if you read the information from Magnum you should lubricate the room fan blower and the auger motor. It doesn't say anything about the combustion blower or where to put the lubricant. Does anybody have any information on exactly where to lubricate and which parts to Lubricate? Also what to use? I doubt that my stove, considering everything I've had to do it, has ever been lubricated. Thanks.
There are usually openings for oil somewhere on the bearing caps at each end of the motor. Most combustion motors are permanently lubricated. 3 in 1 oil should be sufficient for these small motors. Here is an example of where you may find the oil ports.
[Hearth.com] Lubrication Magnum Baby
Reactions: GMadd
Awesome! Thanks!
