Magnehelic Guage use ?
  • Thread starter Thread starter Pallet Pete
  • Start date Start date
P
Pallet Pete
Guest
So my stove dealer is an idiot as I am slowly discovering sadly (very nice guy just not stove smart). I called another stove dealer who thinks I have too much pressure in the chimney and wants me to test it with a Magnehelic Guage. My dealer let me borrow his and told me to put a 1/4 inch hole in the back of my double wall pipe and insert it in by the collar on the stove after it is hot for a reading. Will that ruin my beautiful new double wall pipe or can I seal it after words? Secondly if I drill a quarter inch hole won't that let smoke into the house? Can anyone tell me how to use this thing please?
Dwyer Magnehelic Guage Calibrated for vertical position.
Thanks Pete
Actually, it's a partial vacuum you're trying to measure. Under normal conditions, the air pressure found in a chimney will be slightly less than that outside the chimney. Any holes in the chimney or stove pipe will let air into the chimney (again, under normal conditions - when not in use or very windy days, the chimney might have a reversal of flow).
The hole for the gauge will not ruin your pipe. You need to drill through both pipe layers and insert the hose. Hopefully it is a high temperature hose and it shouldn't be left in too long, nor inserted too far. You'll want to cap the hole with a sheet metal screw (not sure if both layers need to be plugged - others will probably let you know) at least in the outer layer. The screw will deform the inner hole somewhat, so if you need to measure again at some point, the hose might not seal very well. Shouldn't make a huge difference.
Another option is to go up about 18" on the flue pipe and put in a temperature probe. The holes aren't as big as a 1/4", but you might be able to get a smaller diameter hose or small tubing through probe hole. The reading will probably be a bit lower on the gauge than right above the collar, but should be close enough to tell if you have excessive draft.
The gauge will have two ports - one for normal air pressure for reference and one for your sample air pressure. If the needle on the gauge goes the wrong way, switch the hose to the other port on the gauge.
Your double wall is stainless inside and black smoke pipe outside. I do not know the outer pipe gauge. If I was to drill it, I'd drill a 1/4" hole with a nice new bit. Upon finishing the test I'd put in a 1/4" x1/2" stainless bolt and try to secure it with JB Weld cement...neatly! You do want to seal inner and outer. I can't say for sure that it would create a problem with only the outer wall plugged, but you have to remember that every system has a personality and you want yours to be more Jeckyl than Hyde. That means keeping the flue gases where they are supposed to be rather than where they can get;)
I've used Magnahelics to test flue sizes up to 36". Simple reliable instrument. Make sure the metal probe is perpendicular to the flue gas flow so the venturi effect creates the correct draft reading. Good luck!
Thanks for your replies guys there is some very good info here. I believe that I am going to do the stainless self tapping screw to cap while heating up then after until it cools of. The stainless bolt will be put in after it cools off with high heat exhoust jb weld.
Thanks guys
Pete
Curious...what issues are you having?
As good as JB Weld is for some applications, this isn't one of them. It is only good for up to 500F continuous, 600F briefly. The outside layer of your pipe will probably not get that hot (but it could down by the collar), but a bolt that penetrates into the inner flue will easily get hotter than that. That heat will then be conducted to the bolt head and burn the JB Weld under it.
(broken link removed to http://jbweld.net/faq.php)
Thanks for the correction. Given the temps, what do you think would work to simply make it stay in position. Perhaps a slightly larger bolt that would hold tight.
I found the high heet cured jb at autozone it is good to 2000 degrees. I may be mistaken as to the brand however it is two tubes one is a catalyst.
Pete
I'd go with the temp probe mentioned above, then no need to worry about sealing the hole. If you'd rather not do that, then any screw slightly larger than the hole will work. If you can reach up through the stove or disassemble the stove pipe, you could just put a nut on the inside as well.
I think I'd wait and learn the stove for a little longer before drilling holes. Didn't you just get it last week?
On the JB weld, why not simply use furnace cement for the seal?
Seems like geeky overkill to this Mechanical Engineer. A solid fuel-burning appliance and associated flue to daylight is a very simple system. Problems with draft can typically be solved by simply standing back and thinking about what could be causing it, and taking appropriate action (most typically adding some length of chimney pipe up top). Knowing whether the pressure differential between the inside of your flue and atmospheric is 1.8" of water or 2.1" of water one way or another isn't going to tell you anything you don't already know. Besides that, there are so many variables involved (firing rate of stove, inside & outside temperatures, etc.) that your data collected from the precision instrument will be different every time you read it, and you'll basically learn nothing. Tell us what it is about the stove's performance that got you talking to folks about it. Also tell us all about the installation...especially the flue from stove to daylight. Pics are always helpful...holes drilled through double-wall stovepipe for no apparent reason seldom are. Rick
Todd, Fossil we did get it recently however with this style stove you notice the issues right away. It needs the correct vacume to work correctly also it is essential that it gets the right air flow or it wont burn proberly worst of all the atterburner wont kick in. Our issue is that it gets way to hot to fast on low which is dangerious, our house tends to sit in a high wind spot which led to the death of our old stove. When I called harman to see how fast it should heat up they gave me the optimal temp which was 750 flu and 550 stove top. Then thay gave me the time to get there and the issues this stove has when it has improper vacume. My stove has the same issues they described.
First was the fact that it is large and acctually requires more air than my house can provide ( thats a first by the way lol) our house is 1800's and very drafty!
Second it flares very high when you light it up this is due to high wind but only after I crack a window and the stove draws air.
As for the drilling double wall I have decided to fit a 6 inch single wall on the bottom by the stove and drill that out so I wont cry over cracked drilled stainless. I will give a better description as soon as I get on my computer I am on my Ipad and its almost dead.
Pete
Ok so I took a good look at the chimney (Simpson Duravent) and when I finished on the roof moved to the attic. When I got there to my amazement there was a sleight gap between two of the pipes! How in the world can that happen? I screwed them back together and this time anchored them with grade 8 bolts and a metal strap for good measure. Now the stove is absolutely running like it should within 25 minutes I achieved a good coal bed from a cold start. The real interesting part is the shove has the best air control I have ever seen on a wood stove its like a dream. I apologize for not getting back with the specks fossil here are the specks just in case this is just crazy! I did not use the gauge because I could not bring myself to destroy double wall pipe.
The stove sits on a 5 inch tall hearth pad and is supported underneath by floor beams.
17 foot chimney Simpson double wall from ceiling box to top of chimney.
From the stove to ceiling is icc double wall slip 48 to 72 inch.
I have roof supports for the chimney as it sticks 10 ft out of the roof ( this roof is shorter than the second roof 10 ft is needed to crest the second)
Thanks for the advice guys it did sound a little over kill to me as well
Pete
Excellent! Good troubleshooting & action. A thorough visual inspection should always be the first step before doing anything more invasive. Burn on! Rick
