magnum baby countryside
Pops, You should ask this question in the Pellet Mill Corn crib section of the site. I think you'll do better there. Sounds like air feed or pellet feed issue. But the pros will know. Good luck.
pops said:
I ned help stove builds up with pellets someone suggested disconnecting the outside air tube did not work
On the baby the air wash slit is to large aand needs to be downsized. We take a pc of 1/8" rod and put over the air wash slit tack it place with some stove cement. You can also get a high output fan blade that helps also. Your glass well get dirty a little faster this way. Also are you using corn or pellets they have a burn pot for each. the wood pellet pot is a different shape then the corn pot.
do you have your combustion air damper all the way open? Did you check the combustion fan to make sure it's operating properly?
When was the last time a COMPLETE top to bottom cleaning (blowers removed, all ash traps cleaned, pipe cleaned, etc, etc) of the stove done? Sounds like classic "dirty stove syndrome" that isn't allowing enough airflow through the stove.
+1
customer " my pellet stove isn't burning all the pellets up, my glass is black, etc. I keep my stove really clean!"
me " when was the combustion fan last removed and cleaned"
customer "you meam there's more than just vacuming out the firebox and cleaning the chimney?"
me "let me send you a copy of the service manual, you can call back if you still think you need to order parts..."
