I have a log home with a stone fireplace on the main floor. We also have a Fisher Grandpa Bear stove in the basement. Flues from both stoves go up a common chimney. Sometimes when we have a fire burning upstairs we get the smell of smoke in the basement. I am assuming that this is caused by combustion air that is feeding the upstairs fireplace being drawn down through the flue to the basement Fisher stove and into the basement. Since the two flues exhaust into the same space above the chimney the combustion air being drawn in the stove flue pulls in smoke exiting the fireplace flue. The problem is reduced but not eliminated by keeping the door down to the basement closed, which just confirms my theory. And I of course completely close the two air intake vents on the stove doors.
I decided to try adding some gasket material in the groove of the doors to the stove to make them more airtight and thus smoke-filled combustion air will not be drawn down the stove flue to enter the basement living space. The result was that I couldn't close the doors. Judging from comments regarding Fisher stoves on this site it appears that most Fisher stoves do not have gaskets.
There are two bedrooms in the basement and when a fire is burning upstairs the smoke smell is quite annoying. Of course, building a fire in the stove eliminates the smoke coming into the basement because the stove is now drawing air in and up the chimney.
Does anyone have any suggestions?
