manometer accuracy
paulmars
68
fl
What is a good reasonable priced accurate manometer to measure my barometric damper?
My furnace should be 0.025 and my flue should be -0.02. Looking at the gauges for sale i see accuracy (read
inaccuracy) ratings that would make readings in the range that I need almost useless. Exp:
0.3% of full scale 55.00wc (0.003x55=0.165) Does that mean that a reading of 0.02 could be off by as much as
0.165?
+/-0.3% of full scale 83.02 InH2O NKTECH NK-L3 (0.003x83.02=0.249)
±1.5% of full scale 4.00wc Dwyer 478A-0 (0.15x4=0.6)
Am I doing something wrong here?
tks,
pa
0.165?
tks,
pa
If you're just looking for something to use once how about building one out of clear tubing, some water and food coloring. All that matters once its connected is the difference in height between the water level in each end of the tubing.
Dwyer Mark II model 25...$25-30 on fleabay
I used to do large power plant size boiler testing on occasion and my go to manometer was clear vinyl tubing and food coloring. The trick is to mount the tube on a piece of plywood so its sloping at a shallow angle to accentuate the difference in the water levels. A draftsman's tee or dry wall tee makes good tool to mark reference lines on the plywood assuming it cut square. Nice thing about water manometer is there is no required calibration.
i had considered making a unit, but for 25$ that dwyer is available. I dont understand how a home made would be more accurate.
I tried the homemade one...didn't work...bought a Dwyer 25 and done.
I'm not sure how a tube filled with water doesn't work but at that price, I think I'd go with the Dwyer too.
dwyer mark II 25 +/-3% of FS 3.0 is 0.09
so, if it read your pressure at 0.03, that could really be anywhere from -0.06 to 0.12 and fall within the specified accuracy of 3% FS. Now i really doubt that it would swing negative for a positive pressure, so we could effectively limit that range to 0.00001 to 0.12 which is still an awful large range.
pa
Yeah, I couldn't believe it either...but it didn't work...at all.
Something like this?
[Hearth.com] manometer accuracy
From: http://www.hydraulicspneumatics.com/200/TechZone/Vacuum/Article/False/6460/TechZone-Vacuum
Reactions: semipro
Yup, I did the one on the left...no love. I stood there totally dumbfounded...tried a few different things, then gave up and bought the Dwyer ;lol
I do know it works because I've used it other places...but this just seemed to not be sensitive enough to be used on a chimney
A column of water is pretty sensitive. Did the Dwyer work well? I'm guessing the pressure difference must have been really low.
Reactions: brenndatomu
Yes, still using it everyday...I have it permanently mounted for my wood furnace chimney...always check it after every load, just to make sure everything is dialed in...I've caught the barometric damper sticking more than once this way.
Well, many/most wood furnaces call for -0.04 to -0.06" WC column draft....so, yeah, needs to be very sensitive...I've heard of some that spec -0.02" as the minimum! !!!
Reactions: semipro
I faffed around with water manometers for years, and home-made ones are useless below 0.2". The water makes a curved meniscus, and the meniscus has friction at the contact line on the walls of the tube (unless its chemically treated).
I got a Dwyer off FleaBay and never looked back. Just gotta mount it steady and zero it.
One word: Magnehelic, made by Dwyer. I wouldn’t even bother looking at anything else.
I have a few, in different ranges. I even mounted one, 0.25” WC full scale, on the wall behind my stove.
I’m headed out to my shop after lunch, to measure crankcase vacuum on a Kawasaki OHV v-twin, with my 5” WC magnehelic. Incredibly useful tools, IMO.
Lunch is cheese and hard salami with Triscuits and some green olives, with a Weyerbacher Merry Monks to wash it down. Life is good.
been looking at used
2300-00 0.125-0-0.125" w.c.
2300-0 0.25-0-0.25" w.c.
2301 0.5-0-0.5" w.c.
However, inst sheet says:
"Diaphragm in vertical position. Consult factory for other position orientations."
and: "Ranges below 17.5 in w.c. should be ordered using the –TA tilt angle option with the angle specified."
p
Why's that?
The Dwyer Mark II model 25 is a cheaper/simpler (more reliable?) device that is more than adequate for checking chimney draft
One just like that on fleabay pretty cheap right now...1 hour left, zero bids, $24.99 min. bid (broken link removed to https://www.ebay.com/itm/Dwyer-Magnehelic-Pressure-Gauge-Model-2000-0-0-25in-includes-static-tip/173166970609?hash=item28518e46f1:g:OrMAAOSwWVhaifjS)
But I still think the model 25 is more than good enough for checking draft on a wood stove...heck, most people never even put a gauge on their chimneys...but if you can find a magnehelic for same/similar money, meh, whatever floats your boat...
Why's that?
Family used to own an HVAC business, so I grew up seeing Magnehelics in the office. Standard tool in the industry. Every HVAC contactor carries them.
Those water-based manometers I've seen a few here discuss are science project BS. They work, but it's awful hard to measure 0.05" WC with one.
The Mark II 25 may work just fine, I'm not familiar with that one. But it looks like a homeowner-grade substitute for the Magnehelic, and they seem to go for $35, which is the same price as a used commercial-grade Magnehelic.
Mark II Manometers are economically priced, compact and available in both stationary and portable configurations. Construction is simple with virtually indestructible molded white styrene-acrylonitrile housing, indicating tube and fluid wells, molded ABS knobs and zero adjust plunger, shock mounted glass level vial and leak proof "O" ring seals.
SERIES 2000 Magnehelic® Gage is a versatile low differential pressure gage with a wide choice of 81 models and 27 options to choose from. Using Dwyer’s simple, frictionless Magnehelic® gage movement, it quickly indicates air or noncorrosive gas pressures--either positive, negative (vacuum) or differential. The design resists shock, vibration, over-pressures and is weatherproof to IP67.
Have any in my wc range that you want to sell?
Nope, but I picked up the two I have now on ebay. On is 0.25" WC for measuring chimney draft, the other is 5" WC for measuring crancase vacuum and other general purpose stuff. I think I paid $35 for each of them, and one came with a carrying case and stand.
